Has anyone else seen the scanner, even in Beta display actual fuel pressure as incorrect? Across the board the scanner shows fuel pressure to be less than half of what it should be. For instance I see 11,200 psi at WOT however the OEM scanner displays 29000psi.
I can provide a log if necessary
