Page 6 of 13 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 251
Thread: VCM Suite 3.4 is here!
  1. #101
    Sep 2015
    6
    Have you tried checking out romraider? I think there's support for ms42 and it's free I used it for my e36 328 and a m3 works well
  2. #102
    Apr 2007
    1,104
    rtt still has issues with loading. says failed when trying to pull the ve table. then it adds 40% to the entire "shown" ve table. ::shrugs:: back to 2.24 for rtt...
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
  3. #103
    Apr 2012
    9
    I just downloaded 3.4 and now my interface doesn't show any of the vehicles that are on the cable. Any help would be appreciated.
  4. #104
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Run an info log and see if that syncs them up
  5. #105
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    As far as the newer versions opening the older files. I have some saved files I use on swapped vehicles that will not open in the newer versions. The latest version they will open with is 2.24
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
  6. #106
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by mbray01 View Post
    Please open a support ticket so we can fix that for you.
    We got this guy Not Sure, ...
  7. #107
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Does this update do a firmware update that breaks 2.24 compatibility?
    9 sec Montecarlo SS
  8. #108
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    No new firmware update.
  9. #109
    Aug 2016
    Thunderdome
    389
    Quote Originally Posted by La RPM View Post
    HP tuners has stated many times before that they will not provide access to ABS/SRS systems. It's a legal/liability issue.
    As much as I'd like to read that as a rational reply, that logic, if applied all equal to manipulating any proprietary module; it's all a legal/liability issue.
    A response I've read in the past eluded to a lack of bcm development was because of cost/profit.
  10. #110
    Sep 2002
    Chicago, IL
    6,395
    It's cost/profit.
    Getting into any module is usually pretty difficult.
  11. #111
    ]06 Ram 1500 545RFE transmission support? Jtec?[ Any time I ask anything about either, all I get for a reply is; It's not currently supported, no ETA. I would just like to know if these things are planned to be supported, or not. I understand there was a lot of R&D time with 2017 models and Benze support. Respectfully, an answer other than the broken record of Not Supported, No ETA, is awaited. Thank you
  12. #112
    Sep 2002
    Chicago, IL
    6,395
    The reason you get those answers is because those are the answers we can give.
    No ETA.
  13. #113
    Nov 2010
    13
    I prefer to run Window 7 with a "Medium 125%" display size. See Control Panel -> All Control Panel Items -> display.
    Starting with 3.2 and now unfortunately also in 3.4 Editor, the bottom few pixels in each table row are truncated, making it hard to read.
    Guess I should have reported that earlier.
  14. #114
    Quote Originally Posted by mrvedit View Post
    I had the same issue on my laptop..
    2001 Jimmy ,L31 with marine intake,CPC conversion,Nv3500 5 speed,SAS,Dana 44's front and rear,4.30 gears..
  15. #115
    Aug 2016
    Thunderdome
    389
    It's cost/profit.
    Do you foresee it being a something we will see sub-a year from now? There has to be a large market and want if not a huge need based on the oem's making the BCM and other modules more dependent for intercommunication needs.
  16. #116
    Tuning Addict
    Jan 2015
    6,802
    Some of us just noticed this recently, but you can't select individual cells - such as in a MAF hz data log - and then copy paste into the editor unless you select large strains of cells... Can this be fixed please...
    ~Greg Huggins~
  17. #117
    Dec 2010
    3
    I just updated to 3.4 and now it tells me the interface is not found or not responding, and I have run an info log and that did nothing to help.
  18. #118
    Aug 2016
    Thunderdome
    389
    Was hoping 3.4 would enable the scan feature to be used across all obdII compliant vehicles. Tested it out on some that the old version was not able to recognize and still same thing.
  19. #119
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by Blacksheep408 View Post
    Contact support
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  20. #120
    No ETA.
    Please understand I'm not asking for an ETA, just if its something you quys are still working on, or abandone . Thank you.
