Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 78
Thread: Stock GMC Sierra, new twin turbo kit installed, need advice and tune.
  1. #41
    Tuning Addict
    Jan 2015
    6,797
    There should be 3 tables... I'll recheck...
    ~Greg Huggins~
  2. #42
    I never changed the engine this is the stock truck..you're thinking of the original poster this is a stock GMC with the stock 5.3 that originally came into it ...importing the tables should make it run like stock everything is the same I haven't change the injectors , cam anything yet, only thing I changed was the two bar map sensor and adding a TwinTurbo kit. I just need this truck to run to get it home
  3. #43
    Tuning Addict
    Jan 2015
    6,797
    Yes, there's 3 - forgot they incorporated all of the DOD tables into 1 table...
    ~Greg Huggins~
  4. #44
    And I think I worded it wrong it's normal closed normal open and there's a table that says VE DOD which I'm sure I won't touch
  5. #45
    I found the original tables this should get me going great !!
  6. #46
    I just didn't know where to look I found it under the edit tab didn't know it would be there
  7. #47
    Tuning Addict
    Jan 2015
    6,797
    You added a twin turbo kit though right? It's going to flow air differently - that's what I've been trying to explain... If it's not got the turbo kit yet - then yes a stock table should be perfect although they never are... I don't understand why your using the OS upgrade anyway - only thing it gives you is boost enrichment - which if tuned correctly you don't need and baro refresh limits - which is a plus...
    Easiest way as I've said before is to use the bluecat tool - copy data from OE VVE table - swap axis - then copy and paste individual lines from that into your tune... Make all 3 tables the same...
    ~Greg Huggins~
  8. #48
    But now looking at the map K PA the numbers go 10.0 12.5 15.0 17.5 etc. etc. but in the two bar OS it starts at 15 and goes by five, 20 25 30 35 etc. etc. So I'm not sure I can copy these tables into the two BaR OS is there a way around this ?
  9. #49
    Blue cat tool? Do you have a write up somewhere that I can look at you keep referring to saying before but I'm new and haven't heard of any of this ?
    And for some reason maybe I was mistaken I thought you had to upgrade to a two BaR OS once you put in a two bar map sensor
  10. #50
    Tuning Addict
    Jan 2015
    6,797
    In the original tune with the virtual VE click on the map axis - a box should pop up with a drop down - click on the 2 bar "should be the middle one of the drop down options" - this will change it to a 2 bar...
    ~Greg Huggins~
  11. #51
    Tuning Addict
    Jan 2015
    6,797
    Upgrade not needed - just input the correct parameters for the 2 bar map - you have to do this with the 2 bar map OS upgrade too...
    ~Greg Huggins~
  12. #52
    Tuning Addict
    Jan 2015
    6,797
    This is where your map parameters for the 2 bar map need to go - this one is a 3 bar map settings, so won't work for you - what's your map part number?
    ~Greg Huggins~
  13. #53
    So what's the difference in the two BR OS ? Is it better to run a 2bar OS or stick with the original OS ?
  14. #54
    Tuning Addict
    Jan 2015
    6,797
    Here is a SS cobalt map which a lot of people will use for 2 bars and a 2 bar maps settings...
    ~Greg Huggins~
  15. #55
    Tuning Addict
    Jan 2015
    6,797
    The enhanced 2 bar OS keeps your baro from automatically updating - if your at or near sea level then you won't notice this anyway - if your at a higher altitude this can wreak havoc on tuning your fueling... 2 bar OS also gives you boost enrichment - if your VE table is tuned correctly - you don't need it... It does other stuff, but most not needed such as cooling fan enhancements and so on "gives a wider range of control"... OS enhancements are pretty well gone and no longer supported for the most part...
    ~Greg Huggins~
  16. #56
    So I get a little bit more capability by staying with the two BR OS I might as well stay there since I'm already there and learning it.... does the file attachments or thumbnails that you are sending me for some reason it's not letting me view them it may be because I'm on my phone I'm getting on my laptop now
  17. #57
    Tuning Addict
    Jan 2015
    6,797
    ~Greg Huggins~
  18. #58
    this is all a lot of info but I'm slowly learning, thanks for putting up with me. all I want to do in the end is have this truck twin turbo'ed, 60lbs injectors, 2 bar map, valve springs, and 8-10lbs of boost that's it.
  19. #59
    and where exactly is this "map axis"? to change the vve to a 2bar? I cant find it, I'm just finding row axis and column axis if I right click thetables and you cant change, only edit
  20. #60
    ok I need this blue cat tool you speak of... I'm getting it now...you have a link?
