I have a customer who just did a cam swap and mild head work. Tuned the truck, running great. The guy goes to the track, pulls the headlight out and can never make a full pass. After doing some logs and looking into the problem a little deeper, it looks like it's a problem with the ETC and the PCM. I know there's a table that EDIT can see that dictates what a 'safe' limit of air is for the ETC. When the 'safe' limit is exceeded the PCM thinks something is wrong with the throttle actuator and shuts ever thing off, thus 'Reduced Engine Power' mode.
I've bumped the P0101 and P1514 up enough where they are unmistakably not the problem. Those however are evedently not the tables I'm looking for to adjust.
I know there are others with this problem, and I'm sure there are others that have had the problem and fixed it with HPTuners. Any help will be GREATLY appreciated by me and the customer. Thanks in advance!
FWIW, the limit seems to be .72 gms/cyl above 5k.
