Results 1 to 3 of 3
Thread: E38 engine swap questions- No MIL or No error reported?
    Sep 2015
    Santa Rosa, CA
    55
    I am working on a 5.3 swapped into an RX-7. Also swapped to a T-56. In the Engine Diagnostics? DTC's section, should I select No error reported or No MIL for the components that no longer exist? Also, I will be doing a SD tune. Should I let the MAF fail by selecting MIL on first error, on No MIL?
    Thanks in advance!
    13,582
    MAF needs to be on first error along with setting the MAF fail high hz to 2hz. A rear o2 sensor for example can be 3 "no error reported".
    Sep 2015
    Santa Rosa, CA
    55
    Thanks!
