E78 PCM TQ Management Tip In
On my Cruze well any Cruze under torque management > tip in limit enable : enables/disables tip in torque limit based on current gear. This table is lacking slightly in the description to me anyways or maybe I am just a moron or something. Lol. Their is a either a value of 0 or 1 to put into the table so obviously either 0 or 1 enables or disables tip in limiting. Would anyone with knowledge of this table happen to know which is which for enable or disable? Doesn't specify. In my Cruze's tune file it's got 0's in most of the gear values, 0 for 1st, 4th, 5th, 6th, neutral, reverse and park but has a 1 for just 2nd and 3rd gear.
2017 Silverado LTZ
My M6 Sonic has 0 across the board. As I'm sure you know, 0 typically means off in binary. I would assume 1 means it's tip in limit is enabled.
Right. I had "assumed" the same but it was about 1:00 am my time and had been staring at computers all day among many other tasks from the day so was a bit mentally exhausted from the day to say the least. lol
It's always the simple ones that can make you
