List of mods
Cam 219/228 112LSA
Pacesetter LT
Cat delete
Resonator delete
TR6 NGK
Vararam OTR intake
10MM wires
150 Wet Shot Momentary
Auto 4
3200 Stall
1 Piece Aluminum Drive Shaft
LC1 Wideband
Dual Radiator
OE Intake
OE Injectors
OE TB
OE Gears
OE Rails
OE Mufflers
Car only ran 12.41@110 on motor
Added the vararam, tires, and now doesnt want to go faster than 12.38 on 100 shot
Has 150 shot now
Im kinda new to this, but am learning fast.
29 degrees of timing on a 150 shot? Dude... Your nuts saying the LEAST... What pulls timing for this nitrous blast? I don't see a controller listed.. Be lucky if this motor makes many passes that high....
Looking at your tune if you hit the car with any additional cylinder head pressure like NOS, turbo or SC with 26 degrees of timing and no water Meth or 105 race fuel you will cause detonation. The motor will eat itself to death. Even with that if you did not stud the heads you will lift one. All bad. When the NOS hits you have to have something pull timing or you have to run less timing all of the time. If the motor could handle the pressure maybe 10 to 15 degrees if the fuel was good.
