So I want to set up a lambda error graph I have found this thread http://www.performancetrucks.net/for...lambda-524099/
but what I am wondering is when setting up the "Commanded Lambda" - [PID.6001]/Stoich since I am using flex fuel do I have to redo this every time my fuel changes? Also the stoich listing go from 87.5 to 93.75 what if I prefer to run +- 90%? is there and easy way to do this that will always be correct? like a "AFR Commanded/Stoich Commanded" type of setup? if this has been covered, I'm sorry I searched...
