Results 1 to 2 of 2
Thread: 4.3 knock sensor swap
    Aug 2008
    Salem, Oregon
    8
    I'm currently tuning a conversion vehicle that has a 1999 4.3 (1 wire resonant knock sensor) engine using a 2002 (2 wire flat-response knock sensor) PCM and calibration in it with the 1 wire sensor still being used on the engine. False knock like crazy. Other than changing this table in the tune, are there any other sensitivity setting that should be changed? I'm also assuming no segment swap is required for this....correct?
    Advanced Tuner RandomEnthusiast's Avatar
    Feb 2016
    Texas
    333
    I think it would be easier to swap sensors. I don't think you can modify hz detection frequency.
