Ive read on here with you alls great info that when logging at WOT, the maximum engine torque should be higher than predicted engine trq command, otherwise something is limiting. Which is my case here, i see that boost engine tq limit and maximum engine torque are almost identical, which makes me think that the limit is coming from boost source somewhere, any ideas from where? Ill post a log and tune....thanks in advance.
Vehicle is a 2013 malibu 2.0t
Thanks for replying. Yes, i am aware of that table, which is set to 250kpa (around 21 psi), but in log showing 18 psi only avg, i know something else could be limiting.
As these have alot of tables to control power, would like to pin point...so, by having Max Engine Torque lower thank Predicted Engine Tq Command, would that be where its coming from? Or should I be looking somewhere else? If so, id really appreciate guidance to where i can tweak. Thanks Again.
Can you post a log file as well. I need to see torque output, gms/cyl, MAF in lbs/hr, and the other typical stuff, like RPM, TPS, Accelerator Pedal Postion, speed, o2's, and stuff.
For what it's worth, that very table I mentioned remains unchanged in the file you posted. If it's capping at 220, them I'd change that table I referenced above all the way across before looking much further.
