Results 1 to 8 of 8
Thread: Trans Torque Management Issue
    Dec 2014
    Palmetto, FL
    874
    Trying to get my LSA/4L85E Colorado dialed in on the dyno, having quite a bit of issues with doing so.
    I am getting ETC Trans Torque Management and Spark Trans Torque Management kicking in. Closing throttle and removing spark.
    I have all transmission torque management tables disabled in the tune file.
    Attached is the current tune file and the scan showing the issues. I had it commanded 3rd gear with converter locked while trying to do the pulls.
    Thank you
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Is that WB reading right? It's showing like 17:1 in closed loop
    Dec 2014
    Palmetto, FL
    874
    Oh yeah, sorry. The wideband is in the tail pipe, so at idle and some lite throttle it won't register.
    I have a wideband in the pillar that is in a bung located in the header. I am going to put my wideband in that bung, just haven't done that yet.
    Dec 2014
    Palmetto, FL
    874
    Could this be a issue with my TCM controller? What all transmissions does the T42 TCM support?
    Just seems like there are maybe some tables that I am missing in the file or are hidden or something. Honestly don't know, just throwing idea's out there.
    Dec 2014
    Palmetto, FL
    874
    Nevermind, I found my original post that I posted a while back about this issue. And see that someone might have found the fix for my issue.
    http://www.hptuners.com/forum/showth...T42-with-4L80E
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    What was it?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Dec 2014
    Palmetto, FL
    874
    Well I haven't put it to the full test, but has so far work on the dyno.
    Being the T42 TCM is for a 4L60E transmission, there must be some hidden tables that we don't have access to through HP Tuners. I have to email Support still, to see if there are more tables that are hidden or not.
    I had to set the P0717 ISS Low to Disable. (Trans Diag>General>Input Speed Sensor)
    Had to set P1870 Trans Component Slipping Diagnostic Enable Temp to max temp setting. (Trans Diag>General>P1870 Trans Component Slipping)
    Had to set P1870 Trans Component Slipping Diagnostic Disable Temp to lowest setting. To keep from entering diagnostic test mode. (Trans Diag>General>P1870 Trans Component Slipping)
    Before
    After
    Jun 2012
    Rochester
    29
    Hate to reopen an old thread but I'm having similar issues with my e38/t42 swap and Im seeing ETC and Spark torque management pulling a good amount of timing out. What's the side effects of doing what was mentioned in this tread besides the tests not being ran?
    1970 Monte Carlo L96/4l80 swap
    2008 Pontiac Torrent GXP 3.6vvt/6l70
