LS3 conversion 2000 C5 Corvette
Hi
I have a Corvette C5 LS1 345ps.
I have swaped the engine for a 485ps. LS3 engine, mounted with trigger setup from Lingenfelter
( Lingenfelter TRG-002 58x-24x crank trigger conversion module )
and Lingenfelter high flow 90mm. throttlebody
I am getting error code P 1514 "throttle"
Is there anybody can help with a base map for this setup.
I can send supply original file if needed.
Thanks.
Well you might want to make this post into the GM V8 Tuning- Engine, Gas (Gen 4) section.
This is the GM L4, I5, I6 Tuning- Engine section.
Just letting you know, because more people visit that section than this section. And you will be able to get better responses for your specific needs in that section.
But when you do make the new post in that section, go ahead and attach your tune file.
Hello
okay thanks
