Does anyone has the variable cam parameter for this cam ?
VCT angle ?
VCT angle ?
http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
Check our Facebook page http://www.facebook.com/lsxcalibration.com
my findings : you have to limit vct timing to 20 degree max.
(I've set to 18-19 max).
works perfectly
Those are the comp 127600 cam correct? Also If you have the comp 26125 springs, the pressures are too much to control vct correctly. You should lockout and degree the cams accordingly.
If you have the comp 26113 springs you're severely pushing the limits of coil bind.
