I have a friend installing these and I've got everything else sorted out but I need the voltage offset to be converted. As you know the OS used to run them uses pressure delta instead of MAP for the voltage offset. I found the LS1 to LS3 spread sheet but the pressure delta cells are different and don't go as high as they should for this os. Is there a formula I can use to make my own spreadsheet?
