Working on a 2011 6.2 Truck engine L92 with a MAST VVT cam and a comp cams phase limiter.
Im working to dial in the VVT map and have been doing a ton of reading and there is a lot of info spread out on the inter webs. Im hoping to get some real work feedback and have a good VVT discussion in one place for future readers to read.
Im getting P0011 Camshaft Position actuator solenoid high control.
My assumption is the phase limiter is maxes out well before the commanded cam retard is reached and is why I would be getting the code.
Does anyone know what the max range is on the phase limiter? Not really in cam degrees but in real world HPtuners numbers that we see on the map.
vvtmap.jpg Here is my stock VVT MAP
My understanding is 0= around 8 degrees advanced. Basically the actuator is released and the spring pressure holds it at full advanced.
Any number greater than 0 is pulling the cam back from 8deg full advance.
So would 8= no advance?
By looking at my stock map its 8 degrees advanced at idle and high airflow areas under 3800rpm.
At low rpm's and low loads it retarding the camshaft a lot. Probably for help with fuel consumption or emissions. These numbers are where I think I'm setting the p0011 code
at rpm's above 4000 it starts gradually retarding the cam back from full advance. In my brain I would think it would eat to leave the cam a little more advance at high rpm's and make more power
So a few questions
Whats the max number I can put in the map and not set a code with the phase limiter installed?
What are good PIDs to monitor in the scanner and does anyone have a good setup for logging it?
With a larger camshaft are there any gains in idle quality by moving the camshaft around in the idle range?
I see there are some parameters for enabling VVT idle values. Has anyone played with these to help with idle?
