2011 Corvette E38 ECM
I'm trying to do a clutch pedal position sensor relearn but the car won't store any values. Using the scanner I can see the learn status is "disabled" which is why it won't store the clutch fully depressed value. Currently the start switch voltage value is 0.0 volts, which I can't even push the clutch in far enough to obtain that number and thus I can't start the car. I don't know why it's disabled, how it got that way, or how to enable it. I also have a Tech 2 and still can't enable it or get the car to store a value.
I have two DTC's. P080A(clutch position not learned) and P0315(Crankshaft position not learned) which I expected due to a new ECM install. The new ECM is the correct part number and has the proper GM base software on it. This issue was also present with the ECM I removed, however I could still start it because the start switch required voltage was something like 1.4 volts as programmed from the factory. Has anyone had a problem like this before? Trying to get to the track this weekend so any ideas are really appreciated.
Thanks for the help.
