Hello,
I just received my VCM suite and I got everything installed correctly. No errors or issues and I show that the drivers for the MPVI has both the A and B under usb.
However, when I plug it into the truck to try and read the stock tune it does not seem to be working correctly. Here is how I proceeded.
1. plugged in the interface to the laptop and the truck
2. open vcm editor
3. clicked on flash | read entire
4. turned on the truck to the run position (did not start)
5. clicked read. the first time I plugged it in it had to do a firmware update. That completed with not problem.
6. in the window it shows my vin and year, make and model. But under hardware there is nothing chosen. There are a lot of option there, but nothing by default. I am guessing I need to chose a hardware type but not sure what option to choose. If I click read it just says skipping the hardware and then it says complete but never prompts me to save a file. I have looked at the ECU on my truck but none of the number match anything in the hardware list. I am guessing I am doing something wrong and before I continue I figured I would get a little help.
Thanks,
-Sid
