I have a 09 SS TC with the GMS1 hardware, but I copied most of the settings from GMS1 HPT files online. I finally got around to datalogging the car, and noticed the actual boost (subtracting the atmospheric pressure) is limited to 22.4 psi at WOT, and when that happens the fuel pressure is pegged at 2160 psi. I also see the airload at 240% during the same scenario. What I did was find a long stretch uphill and went WOT in 3rd gear. I did the same stretch earlier in 2nd gear trying to do a WOT run to 6k RPM but the front tire just basically went up in smoke whenever I went WOT and the car wanted to go into the shoulder.
Should I limit the torque in 2nd gear? It's set to 100% for all the RPMs in 2nd gear. I didn't seem to have any issues with 3rd gear.
Why is the boost being limited to 22.4 psi? The Desired Airload table was modified. I've checked the other settings and can't seem to recall anything specifically limiting it to 22.4 psi, but it's holding it solid throughout 3rd gear at WOT.
The only thing I saw was the 15 MPa limit for fuel pressure, which is about 2175 psi - close to the 2160 psi I was seeing being pegged when the boost was limited to 22.4 psi. I'm not sure if this is related, and whether I can even increase this fuel pressure limit.
