Results 1 to 4 of 4
Thread: Keyless ignition
    Sep 2015
    5
    Keyless ignition
    In the past I have worked with c5 Corvette's.
    Last week I read a c6 with a keyless ignition.
    I started the engine and read it and everything went well. My question is how are you suppose to read or write to the vehicle. In the past I always did it key on engine off.
    With the keyless ignition I did not know how else to do it?
    13,574
    Doesn't it just go to ignition on engine off if you do not put the foot on the brake pedal to start it??
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    You always want to make sure you're in RUN position, engine not running. Push and hold the lower side of the start button for 15 seconds or so to go into run position.
    Tuner in Training Quoll's Avatar
    Aug 2014
    Adelaide, Australia
    25
    In this thread, Bret from Ultimate LSX Tuning said :
    Quote Originally Posted by ultimate lsx tuning View Post
    ......Mate, Hit the unlock on the remote, and then on the ACC button hold that down for 5sec or more it will say touch the Brake pedal to start don't worry about that , and it will basically go into a engineering mode and it won't have that 5min issue..Cheers Bret
    Please note that this was specific to a Holden Commodore, but may be the same.
