Does anybody know if there is a way setup a filter on chart ve afr error%. I am trying to filter out transition data so say if throttle position changes more than x% in 500ms filter it out.
[50090.156]>50 AND [50090.156.avg(500)]>50 AND (50090.156.avg(-500)]>50
So TPS has to be >50% for 500ms and remain 50% for at least 500ms more for filter to result in True (show the data). Filters on the positive going pulse and negative edges. The time isn't exact so you may have to play with the values if you are looking or exactly 500ms but the TPS percents will be. I also use this approach for Commanded Lambda to filter that lean glitch we always see when the PE engages. Throw in a Fuel trim cell at 0-15 and the Commanded Lambda of 1.0 and .85 and you have all filtering you should need for consistent street tuning. I also substitute the Acc Pedal en lieu of the TPS% as the PCM can sometimes take control of it :-)
Ed M
[email protected]
ok getting somewhere now just trying to wrap my head around it that seems like it would work good with anything over 50% throttle. What I am trying to do is basically emulate the data you would get from a load bearing dyno so i dont have to worry about trying to hold in a cell while also trying to concentrate on driving. Maybe hptuners can't do this.
so say there is more than a 5% variance over 500ms filter that data out
[17.156]>2 AND [17.156.avg(500)]=[17.156] where 17.156 is tps. So that would require the tps to be steady for 500ms to show the data. Now how would i go about adding a variance so that [17.156]+-5% is also shown
well that escalated quickly
[17.156]>2 AND [17.156.avg(1000)]=[17.156] OR [17.156.avg(1000)]<[17.156] + 1 OR [17.156.avg(1000)]>[17.156] - 1 AND [17.156.avg(-1000)]=[17.156] OR [17.156.avg(-1000)]<[17.156] + 1 OR [17.156.avg(-1000)]>[17.156] - 1
[5.242]>170 and [17.156.slope(500)]<1 and [17.156.slope(500)]>-1 AND [17.156.slope(-500)]<1 and [17.156.slope(-500)]>-1
Where 5.242 is coolant temp and 17.156 is tps
If I am understanding what I did correctly than anything under coolant temp of 170 will filter out and any change in the tps +-1% over 1 second will be filtered out
Do you really get much data when filtering it down to +/- 1% per second? I haven't checked over the formula, just curious about the concept.
[5.242]>170 & [2114.156.slope(500)]<2 & [2114.156.slope(500)]>-2 & [2114.156.slope(-500)]<2 & [2114.156.slope(-500)]>-2
5.242 is coolant temp and 2114.156 is accelerator pedal position
Left is with no filter Right is with [5.242]>170 & [2114.156.slope(500)]<2 & [2114.156.slope(500)]>-2 & [2114.156.slope(-500)]<2 & [2114.156.slope(-500)]>-2
not so much getting data as it is getting good data. You can get crap data all day long and have 1000's of cell hits but be chasing your tail trying to tune ve on the street. You can actually take a high positive or high negative number down to 1 or 2 just blipping the throttle thats what we are trying to get rid of
I'm fully aware of the difference. I was just asking if it was working well for you or not. It's something I've been meaning to spend some time on but haven't had a chance yet.
