Results 1 to 5 of 5
Thread: 09 gt500 will not pass inspection monitors
    Oct 2012
    16
    09 shelby gt500.hpt
    Please help. Can anybody take a look at my tune. 09 GT 500 CAI, Long tube headers, high flow cats, meth, 2.6 inch pulley. Will not pass O2 and Cat monitors. Car was originally tuned by someone else with a handheld tuner (not sure what brand). Any ideas? Thanks.
    Advanced Tuner RandomEnthusiast's Avatar
    Feb 2016
    Texas
    333
    Rear 02'S are shut off. Does it even have rear o2's?
    Under engine diag->exhaust try disabling O2Test/O2MIL and CatalystTest/CatalystMIL
    Oct 2012
    16
    it does have rear 02,s, did you see in the tune that they are shut off? I was assuming that also but I don't see where they are shut off in the tune
    Quote Originally Posted by RandomEnthusiast View Post
    Advanced Tuner Witt's Avatar
    Aug 2006
    Pittsburgh, PA
    380
    Engine -> General -> O2 Sensors -> Rear Config
    You have two options with the catalyst monitor. You can shut off the monitor via Engine Diag -> Catalyst or you can leave everything enabled and hope the high flow cats pass the stock catalyst threshold. There are threshold parameters in the PCM as seen in this link however they don't seem to be defined in your strategy. You can email support requesting it to be defined to which they may or may not define it depending on their stance on editing emissions pass/fail conditions.
    If the state you're trying to get the monitors to pass in also require these to not be set to "Not Applicable" you may have to resort to cutting in a pair of green cats similar to what Kooks sells if you can't get access to catalyst threshold parameters.
