File request
I'm having an issue I can't solve and wanted to try a known good file. Does anyone have a 4L80E swapped file for an fbody that they've used before? If I'm going to burn the credits I guess I'd prefer a 2002 file. Car is a 2000 T56 car that I've swapped a 4l80e into and did the segment swap myself. Description of problem here:
http://www.hptuners.com/forum/showth...ting-too-early
http://ls1tech.com/forums/pcm-diagno...too-early.html
Basically the car will intermittently shift at the 0% column of the shift table even if you are at 20-30%TPS.
I've tried rewiring the TPS and a new PCM, no help. For whatever reason there are no files in the repository.
Thanks, any help would be appreciated.
