Inj msec not matching between bank 1 and 2
I have a guys LQ9 swapped nova I am trying to tune for him and I am having some very inconsistent fueling issues even at idle. I have disabled the MAF for VE tuning and commanding OL. I have noticed that the inj b1 and inj b2 ms do not match on the scanner. This is with factory injectors and a BTR stage 3 cam.
Although if I command an afr via the VCM control then they will match and continue to match for a minute or so even after turning AFR control off.
file and log below
robinson nova OL SD ve tuning 2.hptve idle log1.hpl
You have Openloop STFT enabled so its adjusting between banks. Disable that and it should be the same on both sides.
Yea I just seen that a few minutes ago as well LOL. Overlooked it as I don't do much gen III stuff anymore. Will try tomorrow, thanks.
