Requesting Stock 5.4 3V tunes with 5r110 Transmission.
Hey guys. I'm looking for a stock 5.4 3v tune from a 2008+ Super Duty with a automatic transmission.
I'm converting from a gas to a CTD and I would like to use the Ford TCM to control the transmission. I've compared stock 6.0/6.4 PSD tunes to some stock 2008+ v10 files I've found, and I've noticed that the tunes for a PSD have more parameters for the transmission compared to the gas tune.
I'm know the tunes for a gas and diesel are different, but I would expect to see most of the same tunable settings for the transmission since they are both the 5R110W.
A few settings missing on the gas tune are:
Cold Shift:
Exit Temp
Max time
Test Values:
Test Lock in Gear
Test Gear Value
Limits:
OSS Max
Shift Schedule:
Upshifts:
3->5
Downshifts:
5->3, 6->4, 6->5
All of the Tow/Haul Shift Schedule..
Shift RPM Normal - WOT:
Only settings are for 4WD Low
Auto Shift Properties Tab is missing.
TCC Apply/Release Speed is missing
Tow/Haul TCC Apply/Release Speed is missing
Gearbox Protection is missing.
Are these settings are not applicable to a gas powered truck?
Thanks Guys.
I am doing the same and would also like an answer to this.
Exact same plan with the truck.
12V Cummins Swap
Using a Diesel 5R110 in place of the gas.
Im also missing the parameters all the diesel TCM's seem to have available.
