Results 1 to 18 of 18
Thread: Tester Needed
    Oct 2007
    Crawfordville, FL
    2,412
    Tester Needed
    Guys,
    I am in need of someone to test a code modification that should allow for any Copperhead 5.0L to spin to ~8400 RPM without issue. If you are one of the guys on the cutting edge with an automatic car stuck with the issue of not being above to go over 7700 RPM. Please shoot me a private message.
    Eric Brooks
    HP Tuners, LLC
    Tuner TunedByNishan's Avatar
    Sep 2014
    Wood-Ridge, NJ
    106
    PM'd
    www.tunedbynishan.com
    2018 Mustang GT - 10R80
    Jan 2013
    Hawaii
    2,101
    Can I request a video of this if the test succeeds?
    i'm for successful test results. I've got three cars out that would gladly come back for more RPM.
    AAHHHHH!!!!!!
    Oct 2007
    Crawfordville, FL
    2,412
    I have a couple of guys testing now. I'll post the results (good or bad) when I have them.
    Eric Brooks
    HP Tuners, LLC
    i feel bad spinning to 7500 lol. add another grand and ill be shitting LOL. someone spot me OPG's and ill feel better.
    Oct 2007
    Crawfordville, FL
    2,412
    And....... It worked. We blew past the OEM ~7700 RPM limit without issue. Customer didn't want to go over 8,000 since it does not have billet oil pump gears, but this is an awesome result.
    The cams stayed in place as well, and did not revert to 0.
    Eric Brooks
    HP Tuners, LLC
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Congrats on the great work Eric!
    Advanced Tuner AKDMB's Avatar
    Sep 2014
    NC
    344
    I'm guessing this will be a future OS option? What cars/strategies/PCM's specifically were hitting this "hard limit"? Awesome to see this work!
    Sep 2014
    Wood-Ridge, NJ
    106
    EVERY GT' Strategy has this background Rev limiter that can't be exceeded except for the Boss 302 which has a limit around 8200 and the VCT reverts to base timing of 0* cam timing (both cars) once 8000 is exceeded.
    Also, you can't put a Boss 302 OS into an auto car so there is also that issue for auto cars that need to Rev higher (example, cobra jet manifold).
    With HPT's Fix, any Copperhead 5.0L would be able to exceed that 7700 RPM limiter in the code, assuming testing reports back 100% successful.
    This will be a HUGE advantage to using HP Tuners...
    Sep 2014
    NC
    344
    Cool thanks for the info! Any idea on the control pack PCM's? I thought I heard somewhere that they could go past 8000rpm, but wasn't sure about that. You're right about this being a big advantage for HPT assuming testing keeps going well.
    Sep 2014
    Wood-Ridge, NJ
    106
    I know when I run BOSS 302 strategies I can rev it up to 8200 RPM then it starts to limit me.
    When I do this though, I have to spend 4 additional credits (6 total) to convert the strategy and it can only be done to manual cars since the Boss 302 is only manual OS.
    I have auto cars that I have to leave stuck shifting at 7550-7600 to avoid tapping the hidden limiter in the code and these cars usually have CJ Intake's so revving to 8000 is paramount to be in the powerband for every shift.
    Also, the VCT goes straight to 0 right after 8000 RPM regardless of what is being commanded on the Boss 302 strategy. I'm pretty sure the control pack PCM's would do the same (although I cannot confirm).
    Overall, this would make HPT a superior product...
    great news!
    AAHHHHH!!!!!!
    Mar 2013
    45
    Spinning those rpm's!
    Aug 2015
    San Antonio, TX
    179
    What does the Ford Racing TI-VCT High RPM Competition Pulse Ring do? Do you still need this with the code change?
    Edit: Guess the pulse ring is still a good idea:
    https://youtu.be/sVZcmaFTI3Y
    Also, do the 2015's have anything in the background preventing rpm going up to 8500rpm?
    Mar 2014
    Cincinnati
    10
    Quote Originally Posted by TunedByNishan View Post
    I have a control pack that is pulling pretty cleanly to 8200 then banging into a limiter (which is supposed to be set to 8400). Looks like the cams are staying put, though I can't seem to find the right PID to log exhaust cam angles anymore for some reason. It's a manual trans car FWIW. Here's a datalog.
    Dyno 0002.hpl
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by Plimmer View Post
    The TC-1791 has no issue going that high.
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,412
    This feature has been added and is available for Mustang OSIDs that require it for getting above 8,000 RPM. Closing thread.
    Eric Brooks
    HP Tuners, LLC
