Is there a table or tables you need to adjust for different IAT sensors or are they all the same? I need to make sure the data in the tune is correct for my IAT sensor. I was running a 5-wire MAF with integrated IAT then switched to SD and deleted the MAF and bought an IAT from 1998 Camaro 5.7L part#2ATS7 and installed with a breakout harness. I have a ls1 pcm out of a 2002 camaro sport coupe.
I can't really find any tables that allow you to adjust IAT Temp vs IAT voltage. The only tables I see with IAT are the Spark Advance.
Thanks for any clarification.
