Results 1 to 8 of 8
Thread: permanant dtc
    permanant dtc
    hey guys,
    i am using the new scanner 3.0 and when i look at dtc it pulls up a list of codes and they are labeled as (permanant). the 2.24 scanner doesnt show them at all. i try to clear them but they come right back. two of the codes that are permanant are codes i have set to no error reported and no cel light. anybody else had an issue with this.
    I don't know if this will help anyone but the reason I couldn't clear the code was because it was in the bcm and I suppose hptuners can't clear bcm codes. Used the modis and it cleared no problem
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    I have seen vcm scanner read permanent codes, when other scanners couldn't. Talked with keith about this, he said he was going to change some settings so it wouldn't display them.
    it was crazy, you could clear codes, with any scanner, modis, verus, otc, autel, and codes were gone, however 3.0 scanner would still retrieve them. was crazy, but vehicle has reset codes, so I didn't let that concern me
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Oct 2008
    297
    just got around to updating to version 3.0 and my 2010 Camaro also has 3 permanent codes with the new vcm scanner that no other scan tools show or version 2.24,, weird
    2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    It's just showing you info the others aren't. This isn't HPT doing anything wrong...
    Oct 2008
    297
    even if the dtc's are disabled
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yes
    Dec 2013
    Slidell, La.
    1,015
    yes, a permanent code cannot be cleared, even though you disabled the code, the ecm still has to self check. once it does that, it clears itself. Permanent are designed to be non clear-able, for those that go to autozone and clear codes before getting inspected
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
