Results 1 to 5 of 5
Thread: How to disable 07 Edge Pats?
    Dec 2011
    31
    There is anyway to disable Pats on 07 Edge used ECM?
    Oct 2007
    Crawfordville, FL
    2,410
    Quote Originally Posted by hthy View Post
    You should be able to flip the PATS disable switch.
    Eric Brooks
    HP Tuners, LLC
    Dec 2011
    31
    Thanks dear Eric
    Jun 2008
    Waterville,Maine
    8
    Hi, did it work? I have an 09 Lincoln MKZ 3.5 custom swapped into a 1974 Volvo with a used PCM wired up and communicating with my SCT X4 flasher also my handheld scanner. My SCT tuner is unable to turn off the PATS so I'm thinking of getting the HP tuner Suite. Eric in support told me that it supports my PCM It would be comforting to hear it worked for someone else's similar engine. Thanks, Ross
    Sep 2010
    872
    Quote Originally Posted by geerhd View Post
    Pull the file and see if the PATS switch is there. You don't have to license it to view it, so just take a peak at it
