There is anyway to disable Pats on 07 Edge used ECM?
Thanks dear Eric
Hi, did it work? I have an 09 Lincoln MKZ 3.5 custom swapped into a 1974 Volvo with a used PCM wired up and communicating with my SCT X4 flasher also my handheld scanner. My SCT tuner is unable to turn off the PATS so I'm thinking of getting the HP tuner Suite. Eric in support told me that it supports my PCM It would be comforting to hear it worked for someone else's similar engine. Thanks, Ross
