Results 1 to 10 of 10
Thread: rich smell @ idle
    Jun 2011
    12
    rich smell @ idle
    Hey guys,
    I'm relatively new to tuning, but I'm trying to learn. I have an 02 t/a with a 408 lsx 6 bolt heads twin 72's running off of pump gas. The car does not have cats of course. It has a 235/231 621/619 115+3 cam. It has 52 degrees overlap. I was curious if there was anything I could do to tuning the idle where I could get rid of the rich smell. It is running around 15 afr or so while its idling. Hopefully this isn't a complete noob question/stupid question. Any input would be appreciated.
    Jun 2011
    12
    car has 95lb high impedance injectors btw
    Jun 2011
    12
    scan
    Here's the scan as well. I am sd tuned as well.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Install high flow cats.
    Russ Kemp
    Tuning Addict
    Jan 2015
    6,858
    Dial in your injection timing - wont eliminate, but will significantly help....
    ~Greg Huggins~
    Push your injection timing back later to help with the un-burnt fuel getting past the exhaust valve.
    1968 Chevy C10 SWB - Project
    2018 Denali L5P
    Jun 2011
    12
    Ok is there any threads that cover this? I'm all for learning but I haven't really found much
    Tuning Addict
    Jan 2015
    6,858
    Yes - Lots... Your ECT table with move your start of injection "soi" immediately for idle and cruise areas whereas the boundary will move the "border" of where the last possible injection timing can take place - this will also control soi, but more so when getting into throttle - not necessarily at idle..... Make the numbers higher to "retard" the injection timing in the boundary. Make the number smaller to advance it.... If you've got cats, you can probably advance it for better effects. NO cats or boost = better off retarding it... As for your ect table, make the numbers higher to retard it and smaller to advance it - confirmed this to be correct for your OS - some out there are different You might also want to make some of the colder temp areas the same as the hotter temp areas if your having problems more so when cold with things going lean or stumbling with throttle snaps...
    Think that pretty well sums up the basics for you... Now you'll just need to play with it until you find "your" happy median
    ~Greg Huggins~
    Jun 2011
    12
    Ok well I'll definitely study this.... Sorry for another newbie question, but will changing the injector timing get me into trouble regarding afr's and knock? I know that it will be the same volume of fuel being injected, but will that be an issue with boost, timing etc. Can someone point me in the right direction to start learning all of this? I think this would be a really good trade to have under my belt since I have this car which I've built but can't tune lol. Thanks again for the help and I'll definitely start studying this. I think I read in one of your posts ghuggins that you've helped with spool time etc on turbo cars. Would you care to school me a bit on this or point me towards some of those threads as well. Again, I am learning and I don't want to torch my car down so if I'm getting into something that I could potentially get into trouble with tuning wise let me know please. Thanks for all your input guys. I really do appreciate you taking the time for the idiots like me. Chris
    Tuning Addict
    Jan 2015
    6,858
    Any time you change injection timing for the best, you typically richen things up - SO yes, you'll need to most likely retune your MAF and VE tables Usually will help with Knock...
    ~Greg Huggins~
