So I have been trying to calibrate my MAF to the 4" MAF housing and have done a few drives. Right now my Table is set up with LTFT against MAF period. The thing is I'm used to using a custom pid defined as ([LTFT+STFT])/2, this would of averaged out both long and short. From there I could set up a histogram and select this PID to go against MAF period.
The issue is I have not been able to figure out how to create custom PIDS in v3.0. It was easy in v2.24
What I want to do is set up is the following:
LTFT1+LTFT2/2 = LTFT
STFT1+STFT2/2 = STFT
LTFT+STFT/2
IF this can't be done, my other idea would be to calibrate using STFT, once i get those close to zero, change the PID to LTFT
