Results 1 to 6 of 6
Thread: E67 Rev Limit Locations
    Jul 2010
    35
    Starting to get the hang of HP Tuners.
    I am just finishing off the tune on an E67 53L in a 2009 Canyon and it is hitting the Rev Limiter at 6000RPM.
    The hp is still climbing so would like to push it up a bit but for the life of me I don't see where to adjust it.
    Please assist.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Post the tune
    Fuel-->cutoff DFCO, cut off RPM vs. Gear is one I know of for sure. If you post the tune I'll look around some more
    Jul 2010
    35
    Thank you.
    That is odd. I would have never thought DFCO but there it is by fuel then you can switch to by spark.
    If switched to spark does it limit by fuel and spark or just spark. I prefer to use spark only.
    Will play next time on the dyno.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You can disable/enable whatever methods you want. Just disable fuel cut and ETC and enable spark. I would just take it somewhat easy the first time you hit the rev limiter to make sure it behaves like you're expecting it to
    I think you'll have to adjust the "Extreme cutoff" RPM limits also
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    You have few places under Cutoff, DFCO:
    Limit vs Oil Temp
    Limit Extreme Cut Off
    Limit Extreme Resume
    Cut Off RPM v Gear
    Startup Modifier
    LAMP RPM
    On my ZL1 I run Spark and ETC or it does not work as expected.
    Jul 2010
    35
