Results 1 to 6 of 6
Thread: In need of a V3 config, layout, histograms, charts. tuning a 2012 regal GS
    Aug 2012
    23
    In need of a V3 config, layout, histograms, charts. tuning a 2012 regal GS. have a good LNF config for v 2.5 but will not work on v3 and I no longer can run my old software. having a problem loading factory wideband lamda. please help car is on dyno
    Sep 2002
    Chicago, IL
    6,395
    What version of 3.0 are you using?
    VCM Scanner 3.0 includes support for 2.24 and older config (.cfg) and histogram (.hst) files.
    We got this guy Not Sure, ...
    Aug 2012
    23
    3.0.7
    Aug 2012
    23
    the new is a .xml file, the old is .cfg
    Aug 2012
    23
    I downloaded the latest version and got it to open but only a few pids work, trying to get wideband lambda and boost
    Quote Originally Posted by big 3 racing View Post
    I added my Innovate LC-2 WBO2 successfully yesterday using the new 3.0 version:
    1) You need to add a new channel for the MVPI Analog Input the WB signal is on, under the External Inputs tree
    2) You right-click the newly added MVPI input that is now shown on the channels list, select "Transform"
    3) Under the Oxygen Sensor tree, select either Air/Fuel Ratio for 14.7 = stoichometric or chose Equivalence Ratio that outputs Lambda, so I chose the LC-2
    4) To access this parameter to log, when adding a new sensor (selecting the parameter), you can find it under the "fx" tree under Oxygen sensors in the list tree view of all the available stuff
    E67 - 2006 LE5 2.4 Turbo, 444 whp
    E78 - 2013 LUV 1.4T
