I now have a running, driving race car (YAY!!) but the ECM thinks the car is not moving so it only permits 68% throttle opening briefly then pulls back to 30%. I can adjust the RPM it will rev to through Engine>Cutoff DFCO>Extreme cutoff and Cutoff RPM vs gear but the engine still will not make boost or get full throttle. Many people say it's because the ECM is not getting a speed reading from a VSS and this could be, but how do I get around that or how do I get a VSS signal to the ECM? I have a wheel speed sensor sending 6 pulses per revolution to a Dakota Digital SGI-5E converter box which then sends a signal to X2 pin 8 (output speed digital signal) on the ECM. Do any of the smart people on this forum know how to convince ECM that car is moving or make it not care and provide full power? See the race car build here: https://www.youtube.com/channel/UCe5...G1KogAVpWraiIw
