Trans tune for built trans with 3.29 gears and higher stall
So my stock trans went and I bought a built one. Now my car is a supercharged buick regal gs with the 2.93 gears and the stock converter what ever stall that is. The built trans i bought has the 3.29 gears and a higher stall converter from a na grand prix. What tables in hp tuners need to be changed to make this work. I know i have to change the gear ratio in the trans/speedo tab to 3.69 but is that it? And what about the higher stall converter what do i have to do about that. This trans has a shift kit and i have a zzp tune do i need to bump down the pressures? And what about shift points because of the diffrent gearing and the rpm. I really dont feel like blowing up a built trans so if any one can give me some guidance that would be great. Thanks.
