Because of something personal that happened I've sold my coupe and my Solstice racecar is up for sale. Endurance racing now.
Because so many LNF questions have already been answered with other threads, I suggest posting links to other threads to answer people's questions when possible.
Because I don't need to keep it a secret any more I will be posting my tune and explaining the differences between what I do versus others and why.
I won't likely be on here much for answers, though I will try.
As for throttle hang, there are two causes. The first cause of throttle when on THROTTLE LIFT is in the integral gain table:
http://www.hptuners.com/forum/showth...LNF-PID-Tables
The integral gain controls how long the tb stays open. Stock settings cause it to hang open after lifting. You can adjust it tightly enough that the tb closes 1:1 with the pedal. Too high the tb will flutter fighting to close when wot. See thread.
The second cause of throttle hang is your OS table in the LOW LOAD/HIGH RPM area. Values too high there will cause throttle hang when shifting or in neutral.
My race tunes run very high OS values. My entire table is 25. A single value provides for linear pedal response regardless of rpm. A high value gives me instant throttle response everywhere. Very important to remove all lag for racing. But, if you try revving the engine in idle it will cause throttle hang. You shouldn't do that in the first place. I DD this race tune, so it's no issue unless you clutch in and idle at high rpm or rev the engine.
