Page 54 of 87 FirstFirst ... 44450515253545556575864 ... LastLast
Results 1,061 to 1,080 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #1061
    Oct 2013
    228
    I think I got the upload right
  2. #1062
    Oct 2004
    Orlando FL
    766
    This is fixed in tomorrows 3.0.
    97/98 GM LS1 vehicles do not report an OS ID, unless you're running one of our custom operating systems. We require the OS id to determine what OS specific parmaeters are supported. For these vehicles though, we just assume you have an updated OS from GM. This is what we did in 2.24, and what we have implemented in 3.0.
    It will work for most 97/98 LS1 vehicles (just like 2.24), but will likely show invalid data if your operating system isn't updated (exactly like 2.24 would have done).
    Thanks for looking into this, Keith. So it's dependent upon the latest OS for the physical PCM, regardless of the PCM part number, correct? I know I have the latest OS for my physical PCM, but I don't have the latest "411" PCM for the body style.
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
  3. #1063
    Sep 2002
    Chicago, IL
    6,395
    OS, not pcm part #.
    Also, if you noticed, 3.0 should now scan your vehicle twice as fast.
    We got this guy Not Sure, ...
  4. #1064
    Feb 2016
    224
    Is there anywhere I can look in the program to see battery voltage?
  5. #1065
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Should be able to log ignition voltage.
  6. #1066
    Feb 2016
    224
    Ok I'll look for that channel in the list. Also, on some youtube videos going through HP tuners, in tables with "RPM," people have clicked on the rpm part to adjust the limit in that specific table. Nothing happens when I click on rpm while using the 3.0 downloaded yesterday. Is there a new way to do this?
  7. #1067
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    What table in particular? You can click on the headers in some tables (like RPM) and then change them but it's more the exception than the rule. On mine I can do it on the timing tables and a few others but I think that's about it.
    And the voltage might be under "control module voltage", so check out that if you can't find it
  8. #1068
    Feb 2016
    224
    Awesome thanks, I added the control module voltage so when I get a chance I'll test it out later. So far tables such as 'primary VE' and 'high octane' don't do anything when you click on the 'rpm' portion in the title. No other tables that I have looked at so far have let me adjust rpm by simply clicking on 'rpm' however this is my 2nd day using 3.0
  9. #1069
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Yeah I can't do that on my VE table either. I can on the high octane table but that's it
    Are you running the original OS or upgrade?
  10. #1070
    Feb 2016
    224
    I'm using the original OS (stock map).
  11. #1071
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Gotcha. I just checked and on my original I can change the RPM headers on the high octane timing table. It's an OS by OS type thing though as to whether you can change them on yours.
    If the header is under lined then you'll be able to click on it. If it's not, then you won't. So like at the top where it says "Spark RPM (rpm)". If that is underlined you should be able to click on it (same for any table). But if it's not then you shouldn't be able to
  12. #1072
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    I just did a read entire on a 2013 Dodge Charger R/T (no license yet) and can only see transmission tables. What did I do or not do?
    Never Mind, I got it. Can't read it but IO got it.
    Validate Checksum failed, definitions failed to load. Send file and info lof to support. I did so.
    I have a 2013 Charger R/T and chose GPEC2 Dodge from the drop down.
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
  13. #1073
    Feb 2016
    224
    Yes I have no underlined headings Perhaps that's only under 'enhanced' version. My current OS says 12592618 (B0CC).
  14. #1074
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    The Editor "Creation Date" occurs in the future (tomorrow) on a tune I made back in 2015... I have a stock tune from a different car I read on 1-13-2016 and it says created on 1-14-2016.
    Should these match the save date or the original read date?
    2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
    Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
    LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
    ZL1 Wheels/Tires
  15. #1075
    Sep 2002
    Chicago, IL
    6,395
    Could be the 2.24 -> 3.0 transition.
    3.0 has so much more information in the file, full binary change log, etc.. it's a much more feature rich file format.
  16. #1076
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I love the change logs / ability to open previous versions as a compare file. I had some issues with the time stamps for previous versions being wrong in the beginning but I'm not sure if that's still an issue. I'll let you know if it is
    It's pretty interesting when I get sent a tune to be able to see chronologically what's been tried/changed/etc.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  17. #1077
    Oct 2004
    Orlando FL
    766
    Build 3.0.27
    Editor: I can right-click on a table button (such as High Octane Advance) and choose copy, but when I right click on Low Octane Advance, the paste option is missing. These used to be called Copy Table and Paste Table in 2.24.
    Editor: If I open Primary VE, and choose either Copy or Copy with Axis, and then open Secondary VE and attempt to paste it, nothing happens. This used to work in 2.24.
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
  18. #1078
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by JimMueller View Post
    Build 3.0.27
    Paste will not be added back immediately to the navigation buttons. This is because you could end up pasting axis that change your table format without seeing it. We want you to be able to see the changes. We might workaround this in the future with a prompt.
    We're also working on a new paste system for tables that don't line up perfectly (like the 98 VE tables), so you can paste a table with any axis into another table with any axis. Our goal is for the results to be interpolated from the input for the target axis table.
  19. #1079
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    That would be quite awesome
  20. #1080
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Bug found:
    If you use the keyboard shortcut alt+F4 to close Scanner, the layout reverts back to the default when you open it back up.
    Same if you use the Log File-->Exit button instead of just hitting the X in the top right. That might explain why some people have had issues with their layout going back to the default
    This is on 3.0.27, I'll try latest version in a few
