Page 53 of 87 FirstFirst ... 34349505152535455565763 ... LastLast
Results 1,041 to 1,060 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #1041
    Jul 2015
    23
    If theres a solution down the road thats fine.
  2. #1042
    Mar 2007
    DFW Texas
    306
    You can save your layouts all together, you don't need to do it individually. Use the layout menu, or the layout icons on the main tool bar
    If I save just the "layout" not the charts, graphs etc. will it save for example, graphs and allow me to use that exact graph in another layout?
    1961 C-10 5.3 NV3500
    2007 NNBS ECSB 4.8
  3. #1043
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    A saved layout includes graphs/charts/gauges all within the one layout file that you saved
  4. #1044
    Jul 2015
    23
    Another thing I noticed,
    AFR error is no longer supported on the channels
  5. #1045
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Can't add math parameters to the channel list on V3
  6. #1046
    Sep 2002
    Chicago, IL
    6,395
    AFR error is a math pid. It's "virtual" to the application, meaning it's not bound to any particular input, thus, it doesn't go into the channels display.
    Channels display are for inputs that are directly bound to some source.
    We got this guy Not Sure, ...
  7. #1047
    working on a p59 pcm, have latest 3.0. looking for MAF Sensor Fail Frequency to work on LTFT (i am a novice tuner) on my personal vehicle. I can't find it at all. any help?
  8. #1048
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Please post the tune and I'll take a look
  9. #1049
    Advanced Tuner Road's Avatar
    Dec 2014
    Terrell Tx
    478
    Muliple MPVI
    We have two MPVI's in our shop and I am using a different laptop for each one. I see (attached) where the software can now remember multiple application keys and interface license information. Does that mean I can use both MPVI's on one laptop? If so I am going to need someone to walk me through how to do it because when I try it the software doesn't recognize the application key's.
  10. #1050
    Sep 2002
    Chicago, IL
    6,395
    Yes, you can now use multiple MPVI's on one laptop.
    If it's not recognizing your application key, you're copy/pasting it wrong.
    If you enter the application key, and it gets added to the list, it's recognized.
  11. #1051
    Dec 2014
    Terrell Tx
    478
    Thanks I will do that. I was going to do it but didn't want to confuse the software with two interfaces. On a side note: I have spent many hours learning the new 3.0 software with some frustration at times. I am now finally starting to understand how everything works. Normally it's the little stupid things that kick's my butt. You have a good reliable product that gives me great confidant in using it. Thanks
  12. #1052
    Oct 2004
    Orlando FL
    766
    I audited all of the parameters in my old 2.24 config files. I cannot locate the following parameters in build 3.0.27 by searching for parts of their name, which are recognized in 2.24.1172, OS 9375576:
    Idle AC Airflow
    Idle Adapt (STIT)
    Idle advance
    Idle base Gear Airflow
    Idle base PN Airflow
    Idle cracker Airflow
    Idle fans Airflow
    Idle Follower Airflow
    Idle park position Airflow
    Idle startup Airflow
    Ignition voltage
    LTIT Gear/ACoff
    LTIT PN/ACoff
    tcc slip %
    torque mgmt advance
    trans turbine RPM
    When I add these parameters to a 2.24.1172 config and start logging, none are shown as '<unsupported>'.
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
  13. #1053
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    I see its still going on here.
    I need to ask if build 2.24.75 will run beside 3.0?
    I have a truck on 2.24.75 and jut took ownership of a 2013 Charger R/T and would like to run 3.0 on it to get used to it before possibly migrating the truck to 3.0?
    The truck may never be tweaked again, I'm happy with it.
    Did you ever provide a version that will run side by side?
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
  14. #1054
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by JimMueller View Post
    Idle AC Airflow
    Idle Adapt (STIT)
    Idle advance
    Idle fans Airflow
    Ignition voltage
    LTIT Gear/ACoff
    LTIT PN/ACoff
    tcc slip %
    torque mgmt advance
    trans turbine RPM
    Post your tune, and your vcm scanner 2.24 config file.
  15. #1055
    Oct 2004
    Orlando FL
    766
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
  16. #1056
    Jan 2007
    29
    Hey I'm sure it's been asked a million times. But I can't seem to figure out why my 2.24 licensed vehicles all show as unlicensed in 3.0. Application key is correct and shows the vehicle in the list but still can't write the files.
  17. #1057
    Oct 2013
    228
    in the scanner Is there any reason (im trying to learn the new software) that afr error and other thing only come up as one bar when the map is set for 2bar and why the two bar only goes to 160 kpa
    thanks
    Jim
    maybe someone could post one so I could see what im doing wrong
  18. #1058
    Sep 2002
    Chicago, IL
    6,395
    Idle AC Airflow
    Idle Adapt (STIT)
    Idle advance
    Idle fans Airflow
    Ignition voltage
    LTIT Gear/ACoff
    LTIT PN/ACoff
    tcc slip %
    torque mgmt advance
    trans turbine RPM
    This is fixed in tomorrows 3.0.
    97/98 GM LS1 vehicles do not report an OS ID, unless you're running one of our custom operating systems. We require the OS id to determine what OS specific parmaeters are supported. For these vehicles though, we just assume you have an updated OS from GM. This is what we did in 2.24, and what we have implemented in 3.0.
    It will work for most 97/98 LS1 vehicles (just like 2.24), but will likely show invalid data if your operating system isn't updated (exactly like 2.24 would have done).
  19. #1059
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by potatoe View Post
    You need to sync the software with your interface. Connecting the software to the interface and doing a VCM Suite info will do this, or connect to a vehicle.
    If that doesn't solve it, please contact support.
  20. #1060
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by usc45cal View Post
    thanks
    Jim
    Be sure you're logging the 2bar MAP parameter in the Channel display. Post your log and we can see what your channels look like.
