Page 51 of 87 FirstFirst ... 4147484950515253545561 ... LastLast
Results 1,001 to 1,020 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #1001
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    To check to see if an upgraded OS has been applied...
  2. #1002
    Apr 2014
    NW Indiana
    23
    Was tuning a 2012 corvette.. Editor worked very well except for when I went to change rows and columns of virtual ve it would crash. And also the scanner would randomly stop loging WB and or the whole log, and would sometime crash when trying to adjusting logging parameters and/or histograms.. Would have sent crash reports but was on the road for the next couple month I think I will go back to 2.25 till the update worked out. From what I got to use I really liked the new scanner and editor, keep of the good work!
  3. #1003
    Tuning Addict
    6,820
    May just be my computer, but I noticed if you go to (view change history logs) the first couple of attempts the editor just froze, wouldn't open the logs then restarted from original opened editor screen. After doing this 4 times, it finally opened. I know I need a new laptop and may just be my processor speed or something? Just thought I would mention it....
    History logs working fine in todays update 2-18-16....
    ~Greg Huggins~
  4. #1004
    28,272
    Quote Originally Posted by usc45cal View Post
    no reply ??? from you Bill Or support
    Confirmed, two different vehicles, the vcm id number doesn't match, not a software bug on our end.
  5. #1005
    Tuning Addict
    6,820
    Hi Keith,
    I was told to post this here instead of through HP's contact and I know you've had your hands full with everything else, but....
    Just wondering could we get intake manifold volume added to the tunes in general? Even the supercharged cars get bigger blowers added and this effects transient fueling calculations more than anything.
    Then I know it's been discussed, but has there been any change toward baro vs tps update parameters possibly being added or max map or anything like this?
    Thank You
    ~Greg Huggins~
  6. #1006
    28,272
    GHuggins, Keith has very little input when it comes to table adds, as has been stated COUNTLESS times before we do the intake manifold table add on a case by case basis by contacting support.
  7. #1007
    Tuning Addict
    6,820
    Sorry Bill, support told me to post it here. Thought that was odd, but originally had some requests for the editor in there too. Maybe why I was sent here?
    ~Greg Huggins~
  8. #1008
    28,272
    Probably just an oversight, feature requests generally go through the forum. Table requests, particularly ones that we already offer the table on similar applications, go through support. We generally need the file where the table is available, the table id number and the file that you want the table added to.
  9. #1009
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by Keith@HPTuners View Post
    That post needs to be updated and is generic.
    All your flexibility is still there.
    WE'VE ONLY ADDED LICENSE OPTIONS. WE HAVE REMOVED NONE!
    Keith, I don't want to be a pain in the back, I hate to insist so much but I have a real problem, one I never had with 2.24
    I emailed support twice, sent all the information and got the same "generic" answer with a link to the post. http://www.hptuners.com/forum/showth...icles-licensed
    My issue is simple. If I change the VIN or flash a different OS using TIS, 3.0 asks for another license. The VCMID remains the same and 2.24 recognizes my license without issues. However 3.0 doesn't.
    If 3.0 is the future and 2.24 is gone for good, please take care of this.
    How can you help me? I can send you any information you need.
    I have always requested things respectfully. English is not my native language so if any of my requests sounds rude I apologize. Please Help
    Best Regards.
    9 sec Montecarlo SS
  10. #1010
    Sep 2002
    Chicago, IL
    6,395
    If your license is a license against a serial # and vehicle type pair, the vin you change to must be of the same year/model. This restriction applies in 2.24 as well.
    You can't change the vin to a different year and reuse the same license, even if the serial # matches. This applies to 2.24 as well.
    If you are working within these restriction and there's a bug, send us the info and we can look into it.
    Your other option is to do a group licensing option, if its available for your application.
    We got this guy Not Sure, ...
  11. #1011
    Nov 2009
    Pegasus Galaxy
    919
    Yes those changes are within 2.24 restrictions. 2.24 is working fine and is recognizing that the file/pcm is licensed regardless of the VIN/OS it has (as long as it's valid pair).
    Maybe I'm not explaining it right, but the issue is pretty simple. 3.0 doesn't allow changes to VIN/OS that 2.24 allowed.
    I think the issue is 2.24 only married licenses to the VCMID, as long as the VIN/OS pair was valid it allowed write access. 3.0 checks for other things like OS and if something is different will ask for a new license.
    Do you want me to send you the files and info to your personal email? I have sent it twice to support and got the same answer, I think they are starting to hate me
    9 sec Montecarlo SS
  12. #1012
    Sep 2002
    Chicago, IL
    6,395
    2.24 licensed against serial # and the year/model type of the vehicle. There was still a relationship requirement there.
    if you are maintaining this relationship, then send the files to support and link to this thread, and ask the ticket be assigned to me, and I can verify that this relationship is being maintained, and the license isnt' working.
    e-mails sent to me directly go into a black hole.
  13. #1013
    Nov 2009
    Pegasus Galaxy
    919
    LOL at the black hole email
    Email sent as you instructed, Thanks for your patience.
    9 sec Montecarlo SS
  14. #1014
    Feb 2009
    1,931
    Quote Originally Posted by Montecarlodrag View Post
    If you 2 could post findings or keep me in the loop Id appreciate it. I have also expressed this problem and been lectured on how 3.0 allows more licensing options then ever before and nothing has been removed.
  15. #1015
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    I usually update my software weekly, but since 3.0 been updating every morning, so running the latest version.
    as far as sending crash logs, unless windows 10 does it automatically it does not give the option like when the software crashes. When I experience the crash it takes the whole laptop out, therefore no crash log. in the two years I have had my laptop it has never crashed, except the three times in the last 2 weeks, all 3 while running version 3.0
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
  16. #1016
    Sep 2002
    Chicago, IL
    6,395
    mbray, try updating your .net framework.
    When you're experiencing a hard crash like you are, it's more likely a system or driver fault.
    Does it crash randomly, only when scanning, only when playing back a log, etc.. Can you narrow it down at all?
  17. #1017
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by dermotw View Post
    Hi,
    -In the old version (i.e. 2.x), if you compared 2 files, you could see the list of DTCs in each file (and the highlighted differences). Now, it seems you only see your main or active file, the table for the compare one is blank. See below...
    kr D.
    Attachment 56571
    Attachment 56572
    To elaborate on this a little differently. Could we get to a point where we can Copy/Paste the DTC sections or even populate in the Comparison Log so that those parameters can be swapped or copied a lot easier.
    Located in Central Kentucky
    ShorTuning
  18. #1018
    Aug 2005
    Texas
    115
    Quote Originally Posted by LSxpwrdZ View Post
    Yes, want the same thing. Would save ALOT of time.
  19. #1019
    Jan 2012
    Piedmont, OK
    50
    bill, I'm having an issue with new 3.0 scanner crashing. installed latest verson 3 times. I cant log more than a few miles before it takes a shit. i'm running windows 10, latest .net framework, and nothing is fixing it. it looses the wideband first, then freezes and i get a "not responding" when i try to close the program. my blood pressure is getting higher with 3.0.
  20. #1020
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by 1quicktpi View Post
    Please see this thread: http://www.hptuners.com/forum/showth...047#post418047
