My MAP "sensor" is showing 108 kpa at WOT (2016 Mustang) and that is the max map value in the tune....
I know it's not a real measurement but I also don't think that is accurate, either.
What are we doing about MAP (and does it even matter) values and also max air load values?
What are the implications of leaving the WOT air load table stock with modified cars? Too high or too low values?
Why not set the WOT Air Load table to 1.0 all the way across? What is the point of it going up and down as it moves across the RPM range?
etc, open discussion
