hello i'm new to this forum I have an issue with my vehicle and hoping anyone here can help me. i'm sorry in advance if my post is not correct. any pointers on how to make a better post next time is also welcomed.
my car used to have an ls1 with a ls1-b ecu speed density tuned. i replaced it with an ls3 416 but still cathederal heads and went from ls1 to ls3 coils. I did the gen 3 to gen 4 conversion with all the extension harnesses and all new sensors and parts. Got the car running fine. went to the dyno and the car wouldn't rev past 6,300 rpm when we did a pull on the dyno then it would backfire hard, shoot flames out of the exhaust, and then car would go in some sort of a limp mode. you have to cycle ignition then car runs fine again. if you rev it in nuetral it'll rev to the normal redline of 6,850 rpm but would backfire hard when it hits rev limiter and runs bad again, i have to cycle ignition again then it runs normal. here's the things i've done already to try and fix it with no luck.
replaced crank sensor with 2 new ones and a known good one from my old engine while performing crank relearn everytime.
replaced cam sensor twice with 2 new ones.
removed timing cover to verify cam gear is not loose or moving.
measured cam gear to cam sensor air gap and it measured good.
added more good engine to chassis grounds
installed brand new 145 amp alternator
replaced knock sensor and verified all extension harness's are good.
knock sensors are next to headers now but my tuner says he didn't see any knock and even did something to make the knock sensors less sensitive.
scoped cam and crank signals and found signals are not cutting out.
my ve map isn't tuned optimum for the setup right now but it's safe in WOT areas. just wondering if there's something we missed in the tune or anyone have similiar experience. This problem is driving me crazy. i'm not a tuner by any means but i bought a cable just to try and figure this out. I've uploaded my file into the attachments. any help is greatly appreciated thanks.
