I was wondering if someone could give me their option on this. I read in a tuning publication that when you are calibrating in an area that uses 10%ethenal fuel you should change your Stoich AFR in the tune to 14.08 as opposed to the 14.68 in the stock tune.I did this and then obviously it richened everything up.No Problem I recalibrated the VE and MAF accordingly. When my table display is commanding 1.0 lambda I am +- 4% car runs good when warming up and when warm. The problem comes on cold start up. The pcm is commanding 0.77 Lambda because when divided by the richer 14.08 stoich in the tune the colder points in the open loop eq ratio is commanding a richer mixture. I started to adjust the eq ratio then I thought this seems like chasing my tail.Why not go back to the stock Stoich,get to 1.0 lambda at idle and part throttle again and then I wont have to mess with the eq ratio. Because if you do the math at 14.68 the pcm goes back to commanding a fuel ratio that make more sence at 0.83-0.85(12.3-12.5)when it is cold. Any thought on this subject would be great.
