Originally Posted by
PDYoung
No not stock injectors,ID 850. Have an E-force supercharger running 10lbs boost,90mmTB, cam upgrade and a meth system,and headers. I have had it tuned on a dyno after each up grade.Started having start up problems after cam change. MAF/VE tables may have been altered during one of the dyno tunes, i'm not sure, i'm trying to learn this stuff.
Did you look at the log in the opening post? Do you see the spot, shortly after start up, that starts commanding a rich mixture? Isn't the truck in open loop at this point, reading from some table? I have had the same tune since May,now since the temps are getting colder going into winter the start up acts this way sometimes,doesn't seem consistent. Most days start up is just fine,seems like out of no where a startup will act up like the log shows
