Results 1 to 20 of 20
Thread: Thoughts anyone w/ HP Tuners on my data log- Showing KR (ENGINE KNOCK) killing HP
    Dec 2015
    MD
    10
    Hello,
    I'm having engine knock issues w/ my ZL1 that shows up in my data log ...need some thoughts on this issue and possible causes on what needs to be looked at for re tuning.
    Here are my list of current mods
    2013 zl1 6.2L LsA
    -2.55 upper pulley
    -ID 850 injectors upgrade
    -Kooks LT headers 2" pipes to 3" collector w/ no cats offroad pipes
    -Dual fan heat exchanger
    -CAI (Rotofab)
    -Dyno Tuned
    13,564
    Post the tune.
    You'll get more help that way.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Agree.. post tune
    Knock looks like it happens several times in short order which makes me think it might be real.
    Dec 2015
    MD
    10
    LOL of course!!!
    tune attached
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Is wideband working in the log? Doesn't look like it.
    Dec 2015
    MD
    10
    nope i don't have wide band
    Dec 2015
    MD
    10
    just want some thoughts on the fix i'm only doing 11.26s .. and some friends are telling me that I should be running in the high 10s w/ the mods i have on..that my tune needs to be dialed in
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You aren't going to dial in much of anything without a wideband
    13,564
    Agreed, a wideband is a must.
    Dec 2015
    MD
    10
    But do you see anything that is obvious in the tune that could be wrong causing engine knock
    Mar 2014
    McAllen,TX
    160
    what fuel are you using e85 or regular 93? i would wideband it 1st see how its running
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
    Dec 2015
    MD
    10
    On pump gas 93 octane ... what do i need to wide band data log it. I have MPVI Pro
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    A wideband sensor/controller.
    This is what I'm using currently:
    http://www.plxdevices.com/Wideband-O...7346002719.htm
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    you need a wideband, as your 02's are dropping to ~850mv in a few areas which is usually a sign it's running lean... and since you don't have a Wideband it prob was never tuned right to start. Dyno tuned doesn't mean it is right. Until you do that I would pull at least 5deg timing from WOT area's until you get a wideband installed...
    ZL1 Wheels/Tires
    Mar 2005
    Hendersonville TN
    161
    Tune is garbage. All the ID850 data is wrong or missing. PE table is jacked up. MAF table is jacked up. In the log it appears the O2's stay pegged rich all the time and the fuel trims aren't correcting it. And the timing in the log is all over place at WOT.
    Bryan
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    O2's are cycling actually.. though in a weird fashion. They're staying on the rich end a lot longer than the lean side.
    Burst KR is still enabled. I'm a bit curious on why timing is going negative while gear # is staying the same
    Apr 2015
    6
    Wow. Fuel trims seem to be pretty out of wack.
    Im betting that is Burst Knock and it prolly needs to be reduced a tad.
    Im also wondering why the timing looks so low and all over the place at WOT.
    Dec 2015
    MD
    10
    Quote Originally Posted by ZO6_Bryan View Post
    Where in the VCM editor do i navigate to see the fuel injector data , PE table, Maf Table ?
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Fuel injector data. Engine-->fuel-->general--> "injector control" section
    PE table. Engine-->fuel-->Power Enrich-->Eq ratio (gas)
    MAF table. Engine-->airflow-->general-->Airflow vs. Freq low & high
    Jun 2015
    TN
    189
    I wouldn't even start the engine without the proper injector data. Why is the PE table set up like that ? Trying to fudge the values to correct for afr/maf error? Instead of calibrating the maf? Thats what it looks like someone did.
