Results 1 to 10 of 10
Thread: TM Causing "Bucking" Issue 2011 CTSV
    Dec 2006
    16
    On my V at downshifts and sometimes when it upshifts the TM kicks in, the traction control lights up, it pulls a lot of timing, and causes the ETC to close partially. This happens with or without traction control active. It happens when the calculated torque gets over around 420 ft-lb. When it pulls timing and closes the throttle body some the calculated torque drops back down which makes it add timing and open the throttle body. The calculated torque jumps back up to over 400 ft-lb and then torque management kicks in again. It causes a bad "bucking" of the car and also can cause a misfire with the timing going so crazy. I've disabled ETC in torque management, disabled tip-in limiting and maxed out the tables. I also maxed out the other trans input and output torque. I must be missing something somewhere and I'd appreciate any help. I've attached the tune and a couple log files.
    test 10.hpl
    test 10-2.hpl
    Test 10.hpt
    Tuning Addict
    Jan 2015
    6,802
    ??? Glanced at the tune... Looks like all of the torque management is still enabled in the trans and setup to cut throttle? You have increased shift max limits, but... Then you might also want to fully kill powerhop. Then timing needs a lot of work. You don't want over a 5 degree jump between cells typically. Plus I would think you could run quite a bit more than what you are unless you've done some serious boost mods? Anyway that's where I would start.
    ~Greg Huggins~
    Dec 2006
    16
    I don't have much experience with timing and fuel. I took it and had it dyno tuned.
    Where did you see the throttle cut still enabled in the trans?
    Oct 2015
    9
    a shop tuned your car?
    Dec 2006
    16
    Yes. I had it tuned on e85 and 91. He scaled the injectors which caused issues with the transmission and the torque coefficient.
    Oct 2015
    9
    My TM is as follows:
    Powerhop=disabled
    Fast Torque Exit
    Use Fuel Cut & Use Spark=disabled
    Brake Torque Management
    Disable by TCS=enabled
    Dec 2006
    16
    Quote Originally Posted by 10secV View Post
    Powerhop=disabled
    Fast Torque Exit
    Thanks! What are your Torque Management settings in the Transmission?
    Oct 2015
    9
    sending PM
    Tuning Addict
    Jan 2015
    6,802
    Quote Originally Posted by stopltracr View Post
    OK, didn't look close enough to see the tune was scaled. In that case be very careful with timing adjustments
    On your torque management section of the trans tune is where I saw everything still enabled via throttle cut. Make sure your in expert under Edit so you can see everything.
    ~Greg Huggins~
    Oct 2015
    9
    think I got em squared away now
