Results 1 to 5 of 5
Thread: 2015 Chevy/Holden Cruze 1.6 Turbo
    Tuner R8SVton's Avatar
    Aug 2007
    Wollongong, NSW, AUST.
    162
    2015 HOLDEN CRUZE SRI 1.6 TURBO A6 STOCK.hpt
    Hi Guys,
    Ive got a 2015 Chevy/Holden Cruze 1.6 Turbo 6 speed auto and as its my first time doing a little pocket rocket, I would like advise on where to start just as a basic tune to go by.
    Cheers.
    TJ PERFORMANCE
    2014 HSV GEN F R8 SV Enhanced (LS3 340KW)
    6 Spd Manual
    Tuned @ 281RWKW/629Nm with OTR and 100cell CATS only.
    how did you go with this? my sister inlaw has one and wanted me to see if i could make it more responsive as far as gear changes and basic throttle response goes.
    Jan 2004
    Perth - Western Australia
    276
    cruze-157whp.hpt
    This is mine from a manual, but if you compare and copy data into the auto. I would expect you'll get the 30whp difference in top end power and closer to 40-50whp in lower 3-4500rpm range.
    Basically if you add boost, adjust pe to kick in sooner, disable torque shaping they go heaps better.
    be careful those engines dont like more than 310Nm of torque as long as pistons and rods are stock!
    Jan 2004
    276
    mines done over 50k km's, its even been ran on e85 and made 176whp. the stock turbo is what holds the power back.
    like all engines. timing/fuel is what will break it. GM runs these lean well into boost in stock form.
