Well basically we tuned without it and we are just trying to head in the right direction. The tune above is obviously a MAF SD tune atm and my next question is whether it would be better to use the 2 narrow band sensors at cruise. I am told that we can run them below a certain rpm and manifold pressure. The tune is accurate to 1 or 2 percent as it is. Because of the cam I have a false lean spot around the 2000rpm and if I run the o2 sensors it will most likely put fuel in there trying to correct it. I have tried putting 3% more fuel in that area and it makes very little difference. Also using the o2 sensors at idle will maybe make it too rich there as well. I am not certain about the effect of the o2 sensors at idle.
MikeOD, your comment regarding "Pro" means he charges is about right lol. It may not mean he is any good at it though. At least he got it to idle a lot better so I will give him that.
So what I am asking here is there any great benefit in running the narrowband sensors in my application?
