Results 1 to 3 of 3
Thread: how does this look
    how does this look
    2001 Camaro ss 408
    Mar 2010
    were ever uncle sam feels fit
    41
    need a log, what fuel are you running? Stoich AFR14.6 should be 14.1ish for E10..but if you change it to 14.1 remember to up your PE to 1.13 from the 1.17
    Aug 2012
    SV, AZ
    447
    Quote Originally Posted by scites View Post
    Are you kidding me? If this is the quality of advice you give, then please stop giving it. If you honestly think that's the right way of doing things then go read more. If this is something you read our of a "tooning" book, then go get a refund. That's the definition of raping PE tables.
    OP if you change the fuel stoich point in the tune then you should retune the airflow tables. If you're closed loop then you should be fine. You'll end up a little rich at WOT. Don't touch your PE tables. I'm not at my computer so I can't see your tune. Also this is the gen 4 section, your pcm airways to be a gen 3.
