TR6060 to 4l80E swap - What to change in tune??
As the title says. I just finished this swap in my 2010 Camaro. I have a Bauman controller for the 4L80E. I also just purchased HP Tuners (total new-b)! The only thing I have done so far is to disable the clutch interlock. What else should I be looking at? I see lots of tables that reference gear and I am also assuming that the coasting and adaptive idle will be affected. Just looking for some wisdom from you guys. I posted on LS1tch and Camaro, but so far zero responses.
Thanks!!
Still no real good responses. I think my only recourse is to drive it this weekend and do some data logging. Bearing in mind that I am totally new to HP Tuners...what things should I be logging? The car is already tuned by ECS. The idle and low speed manners aren't the best, but it runs good up top.
