Results 1 to 13 of 13
Thread: rich P.E
    Nov 2013
    orange grove texas
    116
    rich P.E
    ]Hello I have been out of this for a while I am have an issue where PE does not change no matter what value I put in the blocks. the truck was FI and now is NA. and when I go into PE it wants to run at .7** lambda. no matter what I tell it to. I have read the sticky and changed accordingly with no such luck. I have to be missing something but don't know what. I have even rechecked the MAF to see if that was causing. still nothing cant be ve as it is disabled in MAF tune. I would greatly appreciate any and all feedback. attached is 6-19-15.hpt
    ok here is the correct log that one was in 2014 when i got hp tuners and was trying to undo what a friend of a friend had done here is the correct log 6-19-15-2.hpl
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Think you can get it to knock anymore?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I spent the better part of an hour looking over you tune and couldn't find anything that was making it do that. What vehicle is it on? I'll try to find a stock tune to compare to.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Nov 2013
    orange grove texas
    116
    I think you for that. you at least responded out of the 96 or so people that have looked at it
    Jun 2011
    Montreal, Canada
    758
    I don't know if this can cause a problems, but I would change the dynamic airflow disable and re-enable to something like 200 / 100. Set the way you have them you could still be using VE under 2500 rpm.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by ke5gnz View Post
    What vehicle is this file from? Sorry if I missed it, but didn't see it stated
    Nov 2013
    orange grove texas
    116
    will change and see if that helps. It is a 2010 silverado with the aluminum 5.3 flex fuel truck with flex fuel 6.0 injectors long tube headers, off road y pipe 4 inch exhaust, 4 inch inlet with ls3 throttle body. lingenfelter 4 inch calibrated maf almost forgot it has an LSA camshaft
    Nov 2013
    orange grove texas
    116
    thank you once again. it just gets frustrating when there is a lot of knowledge out here but few wish to share. I am not doing this for a business but for my own truck.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Looked through a stock one and compared, I coudn't find anything that made sense as why it was doing that, sorry. I hope someone else can find it
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Tuner smokestack's Avatar
    Jul 2011
    West terre haute Indiana
    111
    Mobile. But did you setup the injector flow rates right? Did you tune the O2 sensors for the headers?
    Nov 2013
    orange grove texas
    116
    yes it ran great when FI. I copied the injector data from a stock 6.0 flex tune and everything from fuel millage on dash to fuel used has been accurate MAF tuned right in when I installed the injectors. tuned to o2 for headers? don't know how to do this will reserch tomorrow and see if that has anything to do with it. truck runs good just rich in PE mode and lags some at full throttle, let off a little bit and starts to pick up . than you
    Nov 2013
    orange grove texas
    116
    that is a good read thank you I will try messing with these tomorrow that might be the explanation.
